I had bought a Meshify 2 for my build but to my dismay I had found out that I couldn't mount the CPU cooler to the motherboard because the back of the case didn't have enough space. I knew that someone here had an issue with the same parts but them alluding to a revision made me think that the one I'd get wouldn't suffer it. I don't have the means to modify the case, unlike them. I have contacted Fractal to see what they say, but in case they can't do anything, what cases would you recommend?
I had liked that the Meshify 2 supported a wide array of hard drives, two vertical expansions, EATX compatibility and the fact the distance between the feet would be below 48cm (needed so it could fit on the unit I'd be placing it atop). I was considering the Silent Base 802, but looking at pictures makes it look like having a front mounted AIO (which I had planned in the Meshify 2), would block of f the hard drives and that it might be hard to fit the tubes at the bottom
https://forums.overclockers.co.uk/threads/meshify-2-z690.18941547/
My parts can be found at pcpartspicker with "/list/NDW29r" added at the end. Everything has been bought
