Aorus Xtreme - Brand New Should It Be Making This Noise ?
25 Feb 2019
just got brand new aorus extreme z390
and its making this sound , i have a feeling a £480 motherboard should not be making this sound
any help appreciated as graphics doing similar and will post that later
sysytem is
I9 9900k - aorus xtreme z30 - 32 gb dominator - corsair axi 1600 psu - aorus gtx 2080ti waterforce
well to eliminate the GFX card, remove it and run from the built in GFX only, see if that sound appears again, what cooler are you using on the CPU? AIO system or custom W/C or air?
sysytem is
from what i could see, there isn't a fan like the x399 xtreme version
there is a Gigabyte/Aorus rep on here @GIGA-Man , but should be worth while raising RMA and should have the support from Gigabyte as well if going through reseller
Reject the goods for refund within 14 days, for quickest solution and also to guarantee it won't be replaced with a B-Grade, given that you've only just paid for new. Buy another.
That does not sound correct, so sorry for that. What Danny75 has recommended is well within your consumer writes, if for any reason you don't do this let me know ASAP and I will get it sorted for you ASAP.
