Apex legends constant 50% GPU load issue
23 Apr 2020
Hi there,
Firstly, sorry if this isn’t the best place to post this.
I’m wracking my brain trying to figure out why in apex (my main game) I have 50% gpu load constantly unless I max out the settings but I still get the same frames. So same amount of frames just ups the gpu load to 70%. Running the game at native 1440p.. getting 158 frames all the time. Regardless of what I do in game with the settings. Dropping to 1080p actually gives me less frames (135ish). Any ideas?
Pc specs
I9 13900k
EVGA 3080ti FTW3
Z790 maximus hero
No cpu bottle neck. The cpu is under about 10% load on apex. It should be the opposite, I know the i9 is too powerful for the gpu and really needs a 4090 for max compatibility. But this would mean that the card should be running at 100% to keep up. Cyberpunk has it running at 95% load for example.. so it’s just apex. I’ve gone through every kind of fix around but still no change. I feel like the game is being limited somewhere but in steam I have the ‘+fps_max unlimited’ set for the game and no cap set in rivatuna. I would say it’s just a compatibility thing but I’ve seen benchmark vids of it running on a 3080ti at 200+ frames so I know it’s possible.
I’ve not oc’d the card at all so maybe that’s what’s needed? But the 50% gpu load has me thinking it’s something else.
Stumped.
Thanks in advance.
Hi! Thanks for the reply!​
It’s a Gigabyte AORUS 27" FI27Q-P 2560x1440 IPS 165Hz​
It’s off in nvidia control panel and in game. Is there anywhere else it should be off that I’m forgetting?
Ok I think I may have clocked it. This monitor has amd’s freesync, it was on and now I’ve switched it off it bumped up to 165 frames. So the g sync seems to be kicking in.
I would like to know if the frames would run past 165. How would I do this?
Thanks a lot.
That I don't know, one of the more technical people might help.
You could try using DLSS and upscaling or turn the graphics quality down but to be honest 165 fps with gsync seems like a sweet spot.
the apex game engine limited to 300 fps. To go past 165 you would need to disable gsync s as well as it will be locking to that.
Then it should render as many frames as it can and will show screen tearing as result.
Your best solution is to have gsync on and reflex on. That way the gpu will try to render as many frames as possible in the background and display the absolute most recent frame it has generated.
Thanks a lot.
In-game
Go to Settings.
Go to the Gameplay tab.
Toggle Performance Display on.
Thanks Donnie.
The reflex option is only in game correct?
This is not how reflex works. What you are describing here is fast sync.
Thanks Donnie.
What is your goal here.? You want to run the game at max possible frame rate right.?
The way I understood your question that I quoted previously is that you want to know if your framerate is going over your display refresh rate of 165 since you already disabled gsynv and vsync.
Go into your launch options (steam or origin) and use +fps_max unlimited, this will force the game to run at a max of 300fps if your pc can support it
Thanks. Already had that all set.
I have fixed this. For some reason v sync had turned itself on in the apex specific settings in the nvidia control panel. Plus the freesync being on, on my monitor. Now getting 300 frames easy without any fps limiting in rivatuner at 60-70% gpu load.
Thanks so much all.
