http://www.apple.com/uk/displays/
Will be available in stores in 2 weeks.
£749 with student discount / £899 without
This competes nicely with Dells u2711.
H-IPS panel with glass screen (which i prefer to the AntiGlare coating on the u2711).
I use a 24" Cinema Display at work (PC) with a 4870 & one of these cables: http://estore.circuitassembly.com/p...Female-to-Displayport-Male-Adapter-Cable.html
I'm definately buying one (would much rather spend money on monitors than computer parts - its the most important bit IMO).
It's not just for Macs!
Also, FYI - brightness can be changed on a windows PC if you install bootcamp drivers.
And it isn't just student discount is it - academic staff too I believe. Might look into this for one of my designer kitchen PCs
Only thing I would be worried about is the responsiveness (or lack thereof).
