Apple Cinema Display LED
26 Dec 2005
Hello
I'm looking to buy the ACD LED for my uMB.
Anyone bought one recently, any dead pixels or issues?
If it does have dead pixels can I return it I'm buying it online from the Apple Store
Thanks guys
I've got one. Brilliant monitor if a little on the pricey side. Very bright - makes every other display I use look dull. No other issues or dead pixels though. :)
Thanks for the reply Lowe,
Can you do me a big favour please and measure the length of the cable from the back of the monitor as I need to have the MB in the cupboard below.
Thank you sir.
That's a bit tricky - it's hidden away with a shed load of other cables. It's not very long though, somewhere in the region of 1m to 1.5m long.
Thanks for your help, I've gone ahead and placed an order. Went for the bluetooth keyboard which looks really cool.
You mean the one with no numerical pad? :(
The Apple Cinema Display plugs in to a external power brick, so in theory the cable length is longer, as it goes monitor > brick > mains.
You should be fine for around up to 2.5m.
I don't really use the numerical pad much, took me a while to decide though I love the form factor. I've already got a V470 Cordless Laser Mouse, was thinking about maybe going one better, any recommendations?
Err mine doesn't. Straight from the back of the display to the socket, 3 pin 'kettle' lead.
Thanks for all your help, got it setup today!
