Sorry when I say fails, I mean the test says too hot and stops, not that my PC stalls or freezes. Under Prime I get to 70 degree.
I have set volts to 1.35 not auto. The header is on the mobo, I will use everest to check fan speed this evening.
I think the problem may be airflow. Although I am pulling a lot out via the top and back the airflow in is poor. The intake is at the bottom and being blocked by the hard drives so no air is really entering the case except for the small amount the cpu fan is trying to get in through the meshed front of the case.
I would like a 343 fan module but lian li have changed uk distributers and no where including overclockers have these fan modules which also fit the a17.
I have a bad feeling the psu blowing down might be upsetting the temps as it blows near enough directly onto the HSF.
Slightly confused as to what to do next to improve temps. I can post some pics later
