aquaero controller questions in a loop
10 Jan 2003
staines
right so i have no fan control at the moment apart from off the mobo and i also have my WC loop. heard good things about this controller in a wc'd pc so was wondering just what extras i would need to get the most out of it when i come to ordering one
i know cleeecooo always says about how good they are :)
you think its defo worth getting cle? just i keep looking at it and i want one! but do i really need it :P would be nice to display flow rate and water temp.
Depends. It won't be for everyone. Takes a lot of time to play around with and set up, but once done, it really does look nice. If you're on a tight budget, then not worth it, but if you've got all the good stuff and just want to blow £100, then this is a good product
