Aquaero LT problems
15 May 2012
Louth, lincs
Kit:-
aquaero LT
D5 pump with aquabus
connections
LT>usb>mobo +(molex)
D5>aquabus>LT +(molex)
am i connected right??? its just not showing in aquasuite, checked in outputs (mps) and its not there, what am i doing wrong???
used to have it connected via usb and that was fine, but need to free up a usb header as i only have 2 usb 2.0 and 1 is for the LT
Think i have sorted it... To a degree
Need both aquabus and usb connected, now shows up in aquasuite, set priority to aquabus thinking i can then dissconnect the pumps usb, but no. Thought that was the whole idea behind the aquabus so you can connect direct. Unless i'm doing something wrong??
Doing some cable management and its a pig!! Cables everywhere and not enough room :( next project will be custom made correct length cables, but that can wait, just in case i buy the 900d
