Raikiri said:Pushing the air out the back makes about a 1c diference to case temps if that.
Also this cooler is designed for silence not performance. Although it is a bit better than stock.
Does anyone know when these, and the new zalmans will be out?
Virtual-Hideout said:They're also very quiet which is not surprising since "quiet" is a trademark of Arctic Cooling's philosophy.
Raikiri said:And you cannot measure everything in db, the type of noise makes a huge diference.
mi9tchy said:i like silence
Zephyrus said:Out of interest is it worth while removing the covers on the back of the case for the pci slots when using a cooler that doesnt expel the air out of the case ie zalman vf700-cu? Asking as its one feature i miss from the stock cooler.
Zeph.
mi9tchy said:i need a passive nb cooler for my dfi nf4 anyone know of one that isnt stupidly expensive
