*** *** Arctic Cooling MX-3 Thermal Compound @ £6.99 inc VAT inc VAT *** ***
As an upgraded version of the award-winning ARCTIC MX-2, the performance of the ARCTIC MX-3 out-performs other well-known thermal compounds. This new compound is composed of carbon microparticles which lead to an extremely high thermal conductivity of 8.2 W/mK. It guarantees that heat from the CPU or GPU can be dissipated quickly and efficiently.
Tested and proven, by using the ARCTIC MX-3, the CPU core temperature is 7C and 2.5C lower than using stock compound and other branded thermal compounds respectively. It shows how significant a high performance thermal compound can be to reduce temperatures. Such excellent cooling result is what every overclocker and gamer is looking for. The ARCTIC MX-3 is the easiest way to push overclocking further!
The ARCTIC MX-3 is a metal-free, non-electrically conductive compound which does not cause any damage of the components if it is accidentally spilled out on them. It eliminates any risks of short circuit and provides more protection to the CPUs, graphic cards and other applications between power semiconductor components and heatsinks. The ARCTIC MX-3 is a truly hassle-free premium thermal compound you can rely on.
- High Thermal Conductivity
- Low Thermal Resistance
- Non-Electrical Conductive
- Non-Capacitive
- Non-Corrosive
- No Curing
- No Bleeding
Only £6.99 inc VAT.
ORDER NOW
![TH-002-AR_400.jpg](http://overclockers.co.uk/pimg/TH-002-AR_400.jpg)
- Non-Capacitive
- Non-Corrosive
- No Curing
- No Bleeding
Only £6.99 inc VAT.
ORDER NOW
