Arctic Cooling MX-3.
I had AS5 on my Barton 2500+ mobile and would still be using it (the AS5, not the barton ;)) had I not loaned the tube to a friend last year and not seen it again!
If you have paid for a tube of TIM, use it: there is little point in throwing it away to buy something that will give you two or three degrees lower temps at best.
Probably more like 5-6degrees over as5, and it's cheap anyways, but then I build quite a lot of PCs so I don't have a problem with finishing the tube.
PS. Apply it to your GPUs as well !
