Hmm... The pack comes with a voltage regulator heat spreader. However... The OcUK x1950 pro is not a reference design, and the heat spreader doesnt fit, or appear to go anywhere.
Do I need to install the voltage reg heat spreader? Or can I get away with just the heat sinks and cooling part?
