I have just fitted my Arctic Freezer 64 Pro and have a quick question.
I'm pretty certain everything is fine but I like to just make sure.
The copper base of the heatsink is smaller than the metal contact area of my AMD64 3700 so there is a surrounding edge of CPU that isn't in contact with the heatsink.
Also although the heatsink is fitted correctly and secure it isn't quite central on the CPU.
So the exposed edges are like this
Front - 0mm
Back - approx 2mm
Left - approx 1mm
Right - approx 3mm
as viewed looking at the fan.
Does this matter - I guess the best I could do is font/back = 1mm and left/right = 2mm
I could take it off and try a bend the brackets a bit but to be honest they look like they are sitting right on the mount.
Any thoughts - never has a heatsink that didn't completely cover the CPU.
Cheers,
Nigel
Front - 0mm
Back - approx 2mm
Left - approx 1mm
Right - approx 3mm
Cheers,
Nigel
