OK, I've quickly had a shot this morning to change back to stock.
So far OC'ed to 2.5GHz.
Started with Freezer Pro 64:
idle = 42C
load (dual prime) = 54C
I was a bit disappointed, so tried the stock HSF.
idle = 44C
load = 62C
Looks cut and dried, however when I took off the AFP64 I noticed my rice grain-compression-spread method hadn't covered the whole IHS. I've now reseated the AFP64 with a touch more (fresh!) AS5, and I'll see tonight if it's cooler than 54C.
As well, though, after trying the stock HSF and removing it I went to clean it, and the TIM was like dried chewing gum! So perhaps it will perform better with AS5.
I have to say the temps weren't lower by as much as I'd hoped. I'll have a better shot at the w'end.
