I don't see why that would be a problemWhat if someone did an alternative level 3 qualification (not A levels, but an equivalent)? That catered for on application forms?
Not to a sensible employer, especially once you have experience, do a Sandwich placement.
I don't understand where some people are getting this idea from. The top graduate schemes all look at your UCAS points. IBM, Accenture, Shell, Exxon Mobil are all companies that will take your A levels into account.
You can't call some of the most successful businesses on the planet "not sensible employers".
In the old days when A Levels weren't dumbed down they were a very good indicator of academic achievements. Nowadays, they are not really an indicator of someones academic ability.
They aren't dumbed down today whatsoever.
Certainly, in the case of the OP there's little point in doing extra A-Levels now. The point I was attempting to make was that when employers want to rate your degree, they simply look at your A-Level score and infer from those what type of University you went to. So whilst it's already set in stone what University you're at or where you went, employers will always use your A-Level results to determine that standards at the University.
In the majority of cases the correlation will be very strong, but of course, as with everything in life, there will be exceptions. Regardless of how strong the link is though, it's what companies use to rate a degree (or rather, make sure its standards are above some lower bound).I know what you're getting at, but you've gotta remember that the standard of University people actually go to is not always directly proportional to A-Level results.
Yet despite a B and an E @ A2, I work for IBM.
Did you enter the company through the grad scheme?
I'm not sure on what point I've been unclear. No one has suggested that this means of assessment is bullet-proof. No one has suggested that there aren't exceptions. Companies need to use some sort of yardstick, and a fairly good one is that of the grades required to enter into a course. They use it as a means to judge the University people went to. Of course people who went to Oxbridge will have got good grades - in this case the system works: they all point out they got AAAAA+ at A-Level, then low-and-behold the companies filter system assumes they went to a good university.That's just the point I'm making.... it doesn't make sure that the standards are above a lower bound.
