Are all HDMI cables the same?
7 Sep 2008
Hi guys,
I recently bought a samsung soundbar like this:
https://www.samsung.com/uk/audio-video/soundbar-q60r/
I have a Samsung smart TV too.
I have connected the soundbar to the TV via the ARC HDMI port.
The problem is that the soundbar will work fine but when I turn the TV off and then turn it on later on
the hdmi input just doesn't seem to work properly. Also when I turn the power on the TV I have to seperately use the samsung soundbar remote to turn that on (they are all the same make though)
I checked the settings on the TV and I get the option to change it to HDMI but still the soundbar doesn't work via HDMI. Sometimes on the TV it will say "unknown" on that input port.
I read online having a HDMI cable will allow me to have dolby dts and something else. So I believe HDMI will be better over an optical cable.
I'm suspecting that the old HDMI cable could be the problem here, do I need a newer HDMI cable to solve this issue?
p.s the soundbar is awesome it fully works on a BT connection.
Those branded as "Premium" are independently certified to support 4k/HDR - considering they cost very little more than "unbranded" I would recommend purchasing such as you know you won't have cable issues.
UGreen is a brand that was on Amazon that sell certified Premium cables - I paid not much more for them over most other cables and they have all done their job.
On the flip-side, I purchased 3 Amazon Basics HDMI cables previously - got "sparkles" all over my screen when displaying in 4k/HDR (They vanished if I dropped to 1080 or switched HDR off). As soon as I replaced these cables with the aforementioned - all problems vanished.
I had a problem with a Sony TV and soundbar where the auto power feature of the soundbar was causing issues. I had to turn off the auto power off feature to then allow the TV to control it. I had a similar problem where it would turn off shortly after the TV, but then when it powered on it would be using the optical input not the HDMI so I kept having to manually change it - until I changed the auto power function.
I've had no issue with 4K HDR playback usng the Amazon basics cables.
thanks RTFM :)
- Bluetooth reconnects - got to turn it off
- Any Net + = got to turn off
- Auto power link = got to turn it off
