Are any of you noticing a fuel economy impact running E10?
Caporegime
21 Oct 2002
Here
Sure.. Sure.. True.. True..
Except I know my car and the difference was night and day, other cars may be different but a 211ps 2.0tfsi quattro TT does NOT like this slurp.
This thread isn’t about washing machines. My 414ps 4litre V8 doesn’t seem to mind the tank full I just put in
Permabanned
28 Nov 2012
So your car has a misfire, definitely the fuel then.
It was fixed by filling up with 98 Ron (even though my cars designed for 95)
Luckily, that was very easy as with the E10 the fuel went much quicker than normal!
YMMV.
30 Sep 2003
Norwich
I love it when someone who has been a member of the forum for 9 years clocking up less than 20 posts suddenly activates and talks like someone from 15 years ago! *popcorn.gif*
14 Apr 2014
Sunny Sussex
I know my car. The difference was night and day, I'm not going to argue with any derp that disagrees as I've physically had the experience.
Also my engine idles like **** on it, I actually thought I had a misfire until I remembered, ah yeah, that new fuel!
People blindly believing lab results because some **** in a suit said something is something is genuinely full retard.
As we know, you NEVER go full retard.
Lol your posts are funny
Big chips perhaps?
Permabanned
28 Nov 2012
Only 414ps? Damn that must drive like a ******* winnebago with all that weight!
Is it sitting on the front or rear axle though?
The answer to this question will prove how much of a tool you are.
(P.S - Id smoke jouuu)
Permabanned
28 Nov 2012
how olds the car ?
2014. 8J MK2 not 8S MK3.
Everyones going to get different results in this but my engine runs like **** on it. Its not ******** just because some lab experiment designed to make everything look ok came back looking ok.
ok?
5 Apr 2009
Hard to take anyone seriously who's claiming with a straight face that a fuel which is about 2 or 3% less energy dense has caused a near enough 20% reduction in economy figures. Even accounting for an appropriately capable engine perhaps running more efficiently on a higher octane fuel, that's just way beyond believable.
Caporegime
21 Oct 2002
Here
Erm. Answer is a pipe wrench ?
Permabanned
28 Nov 2012
I'm not the only one reporting it and what do I have to gain?
Running great on 98 RON. Go figure.
2 Mar 2004
SE England
There's negligible difference between the two in my Swift, in similar conditions, on the economy front. The calculated MPG often hovers around 40; I did some 300 miles recently on a tank of 95, turned around and did the same distance on 97. Worked out as 38.97mpg on 95 and 38.19mpg on 97. That's been repeated since, approximately, too.
It has historically returned its best on super, though, and I did recently get a batch of 95 that it was particularly unhappy on – plenty of low-speed knock. It is quite sensitive to fuel quality, mind, but I think it was probably just the fuel from that particular station. It hasn't exhibited such significant issues on subsequent tanks. Regardless, I prefer to opt for the best fuel available; I've just had to use 95 a few times due to availability issues.
The Corvette isn't troubled by it and returns similar economy on 95 as it does on anything better, and runs just as hard on either. But then that's just a simple naturally aspirated engine with an unremarkable compression ratio. Again, I'll usually stick the best available in it if possible, though. Every little helps...
5 Apr 2009
50 million cigarette smokers can't be wrong! :p
As for what you have to gain, who knows other than you? I'd love to hear some genuine logic and reasoning as to how 2 or 3% less energy in your fuel has caused a 20% decline in your economy alone.
Permabanned
28 Nov 2012
You assume the lab results are accurate, and not skewed or aligned in such a way as to push the real agenda here in helping the EU reach climate targets they will fail to meet anyway.
I mean, apparently E10 is a European SUCCESS story you know?
Whats cigs gotta do with this? As in 50 million people smoke so it must be good? Is that your logic? You can do better surely. DERP
5 Apr 2009
Cigarettes being the famous Simpson's joke taking the **** out of people who use logic like "I'm not the only one" and assume it validates whatever point they're (usually badly) making. I'm surprised you couldn't figure that out yourself.
Besides, I haven't mentioned lab results, i'm asking you to provide some sort of logic to explain how 2 or 3% less energy results in 20% less economy. Can you?
If that is all that is different with this fuel, then why will some cars absolutely not run on it?
Riddle me that, bitch!
Because of material incompatibility that will degrade hoses etc. over time, not because the engine won't run.
