Are sky boxes paired with the dish
  • Thread starter Thread starter Faz
  • Start date Start date
Faz
Faz
18 Oct 2002
Just want to know if I take my box and card to the girlfriends, will it work connected to the dish at her place?
Cheers
Cheers
The boxes aren't tied to anything, I brought my box over from England and it works fine with a pre-existing dish.
No, you just have to re-pair the card to the box you want to use it with. There is a hidden menu with the ability to do this. Press services-4-0-1-select and then select the new installation option. The box needs a phone connection to do this.
phone sky, tell them the serial # of new box. They match them up. Job done.
Card works fine without this for family pack channels, sports/movies/recording etc (sky+) needs it to be paired.
