are SSDs ok for database and wordprocessing
Yes, absolutely fine.
If you're asking because of concerns over the number of SSD writes, it'll be several years before you're even close to that limit. The PC itself will be obsolete long before then I'd imagine.
There used to be a preference for SLC over MLC due to the number of write cycles they support being higher.
People are using SSDs in enterprise SAN/NASs now, so I wouldnt worry to much about write limits. Even used 24/7 they should last ages.
Longer than Seagate disks at least :D
Enterprise SSDs are still eye-wateringly expensive - but the performance increase over even 15k drives is HUGE. So if you're seeing a database with poor IOPS performance, consider it.
