Are there any drawbacks with Modular PSU's
11 Jun 2005
Cheshire
As the topic really, going to get a new 600w PSU, will probably get a Tagan, always bought them in the past (a bit pricey i know, but never had one fail yet) and seen that Tagan do a 600w Modular version and was wondering if their as good as a standard PSU... I would like a modular as it would reduce the clutter within my case in my new C2D build... ;)
Thanks for any help...
there are no drawbacks with modular power supplys, its the same as an ordinary power supply just with the cables not attached, ive only just upgraded to a modular power supply and i would not look back, my case is so tidy now
Thx for the replay m8... Was in the Cases thread and people have been posting pics of cable management, some tidy pc's, and i thought a modular psu would really help... Will place an order, thx... :D
Thats the thing that worries me about my new build, the case, im going to get an Akasa Eclipse, just hoping the cables from the PSU will reach all the components... :confused:
The case in your pic looks nice and tidy, the pc in my sig looks like an explosion in a octopus processing plant, really want a tidy build for my new pc, plus it will help with cooling, as i'm going to be on air... :(
modular psu,s r easier kept tidy, but ive notced theyre a bit more expensive
akasa eclipse is my next upgrade, my current case is far to cramped, was a bad choice when i built my first rig, but you learn from your mistakes, im sure someone will buy it lol
Expense is the only drawback. I suppose there's also a possibility of you losing one of the cables that you might need in the future, but that's just down to how organised you keep things.
Technically because of the modular connections slightly more power is required than for an ordinary non-detachable system but the amount is negligible so it is more of a theoretical than real problem. You do additionally have the slightly more likely problem of the possibility of breaking or damaging the modular connections themselves which is less likely in a standard non-detachable system.
However the drawbacks are more than outweighed by the positives in my view, I'm just highlighting the above in the interests of providing fuller information. :)
One draw back is that there might only be one SATA cable (with two connections) so if your CD Drive and HD are far apart you might have to stretch it a bit, or get a converter Molex > SATA thing
