Are there any speakers that allow two PCs to use them?
15 Nov 2003
Marlow
I've got two PCs next to each other, and it hit me that it would be nice if I could allow both systems to use one set of speakers...
I tried just plugging both systems into my existing unit, but the moment the second PC was attached I got a feedback buzz.
I suspect the answer is no to this, but it seems daft that I'd have to have 8+ speakers and 2 woofers for two PCs....
daven1986 said:
did you get feedback even when one PC was off? I suspect if you use one set with both PCs on it'd 1) cause problems and 2) sound bad.
I put a splitter into the speakers, and the moment I attached more than one soundcard to them, I got buzzing.
In an ideal work I'd just want both PCs just to play into the speakers (even at the same time)... The above solution does this, just I get the annoying buzzing...
greenlizard0 said:
Try using connecting it to an amp, then the amp out to your speakers. I think that's a more effective way of doing things.
I have surround sound speakers...
This just aint gonna fly is it :(
I do exactly that. I have one of the high end Creative 2.1 systems, and it has an Aux in. I have my desktop into the main speakers input, then a little cable from my speaker out on laptop soundcard, into aux in.
We could get snobby about sound quality, but for me it works sweet (apart from I need to get mixers for my laptop, but thats to do with music production and irrelevant).
They can both play at once if I want them too.
