Are these specs good?
Tay
Tay
16 Apr 2022
Essex
- Intel Core i9-11900K Processor
- NVIDIA GeForce RTX 3080 Ti Graphics
- 32GB RAM, 1TB SSD (M.2 NVMe)
- Windows 11 Home
- Corsair 4000D Airflow Mid-Tower ATX Case
- 240mm AIO Liquid Cooler, 4x 120mm Hyperloop ARGB Fans
Are they good? High end?
Name of competitors is not allowed under forum rules so you may want to edit the cooler name.
Do not get an 11900k , stupidely power hungry for the performance it gives. Look for a system with a 12700k imho, no real reason to go for 11th gen and a Ryzen 5800x/5700x would be preferable to a 11900k.
What do you mean by power hungry? Is there a big difference between the 11th gen and 12th?
12th gen can use a lot of power when it is doing productivety tasks such as blender but it is surprisingly efficient when gaming. 12th gen was a significant step up in performance over 11th gen and it went from the advice being ignore 11th gen and get Ryzen 5000 chips to get 12th gen Alderlake. It is a return to form for Intel and is a far better choice than an 11900k which is generally considered to be the worst chip in the 11th gen due to its poor performance/Watt.
If you tell us the sort of budget you are thinking of spending we can spec up a prebuild for you to consider.
You may also want to consider waiting a month for AMD to release AM5. This may drive down prices on Intel chips and save you money. There is also the insane deals on AMD gpus at the moment , do you really want an Nv card ?
That is an insane deal for a card that will beat a 3080ti in every benchmark that does not have ray tracing.
