Hey,
So I've recently been worried about my temps, noticing that they seem quite high, and not being sure how long this has been the case.
I came home tonight, to my computer idling all day, to find my GPU temp at 35c and CPU temp at 40c
After using the computer for a bit, the CPU temp was averaging 45c (NetFlix, installations, etc.)
After running several benchmarks (Unigine Heaven, Metro 2033) the maximum recorded temps during the entire benchmarking were 85c on the GPU and 85c on the CPU.
After closing the benchmarks, the CPU temp was back to averaging 45c.
Are these temps alright? 85c sounds will within spec for the GPU, but I'm curious about the CPU.
Thanks in advance
Thanks in advance
I was a bit obsessed a few years back and probably ended up spending hours just to get temps down a degrees or two!
