You screenshot shows you only have 135MB free![]()
I am thinking the same, out of interest what version number is on your XMS3 you have
I might just get it in. Won't hurt, will look cool and I can always sell mine for a bit.
Will that RAM I linked to work on my AMD setup no problems?
I dont see why it wouldnt but I would go for the faster 1600mhz ones here:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-062-GS&tool=3
Not a bad idea, whats the difference between those and these though?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-060-GS&groupid=701&catid=8&subcat=1517
Fair bit cheaper.![]()
I could be very very wrong but was thinking with higher resolutions etc now if your lacking vram wouldn't it then start making it up with system ram?
if thats the case having more wouldn't exactly hurt as not all cards have 2gb vram.
