Arghhh please help
10 Jun 2009
Darlington
Hiya all.
Right im sucking me thumb here looking a complete and utter prat!
Today I recieved from good old OCUK my Swiftech pump for my new watercooling project. I took it apart as you do and when I went to attach it to my xspc dual bay res the screws are to short!! I bought the res second hand and it didnt come with any extra screws so at the moment im stuck for fitting. Anybody know where I could get some spare screws or the size so I could maybe go and get some from a hardware store?
The next is ( haha ) I also had delivered 4 asaka viper fans. I was going to attach these to my 2 dual rads but they came with 4 long rubber things which I assume are the anti vibration fittings! But I need screws to attach to my rads so again what size and where would I get them from please? Or could I use the anti vibration ones?
cheers all for your help and replies and please be kind with your comments haha
Not sure about the res question, but what rads are you using as not all rads use the same type of screws. This info will be needed for anyone to post to help.
Well after a quick google I have come across the xspc homepage and found my exact res with a very handy pdf. Seems I need m4 screws for my res so thats easy enough to get and it looks as though my rads are going to need either m3 or m3.5 so all seems to be sorted. Phew. Cheers all
