- 25 Dec 2002
- Brighton
Postman came yesterday wohoo. Delivered my new Lian Li Armorsuit PC50-WB & the Corsair H50-1.
Original Case was a Lian Li PC60 about 4years old, still looking well though.
Eventually decided on using the Noctua NF-P12 Fans in Push-Pull config as an intake.
2 x 140mm top Exhausts
1 x 120mm rear Exhaust
1 x 120mm front Intake
2 x 120mm Intake and CPU Cooler.
Had to use a bit of creative thinking to mount the H50-1, but its well secure, although im not entirelly happy with it atm.
Just need to finish it off with a couple of Lian Li Stealth Bezels, and some internal lighting.
Temps have dropped from 40*c idle & 84*c max load. to 34*c idle and 72*c max load. I also used to leave the side panel off my PC60 too. Noise wise shes no louded than my old case.
Well Pleased
Well Pleased
