I have a prob here, Ive just installed arctic cooler freezer 7 pro on my dell XPS 7100 and now and then I get CPU fan failure at start up, only come once if I reboot I cant see it on screen,but if i live PC off for a certain amount of time it comes back, Ive checked fan is working properly temps are great 18 degrees IDLE,cables are in the right place and all seems normal I've checked bios but cannot see any options, any ideas what is causing this and how I can fix it? Or shall I just ignore error?
Cheers
Cheers
