artifacting problem
30 Nov 2007
ok ive made bit of a sidewards step / backwards step with the choice of card
ive just sold my evga 65nm core 216 and bought a evga sc 55nm.
trying to apply the clocks i gained from the 65 to the 55 is causing artifacts in atitool tester.
my question is, is this right ? should this happen ?
i have read on some review that the voltages on the 55mn are different to that of the 65nm so im assuiming that this is whats causing me not getting the same clocks
clocks from my 65nm were 740 core 1540 shader 1220 mem, and that was stable, with the 55 i cant even get close to them
try de-tuning it a little with riva tuner. will most likely solve the problem but then your stuck with a card that wont do what its sold to do....... I bough a watercooled MSI 280 Hydrogen a little while ago... artefacts in 3D games and benchmarks at its rated 700mhz shader clock.. runs fine at 680. I decided not to RMA my card as getting a replacement would be A) hard and B) most likely much more expensive as I had a good deal on the card
if i thought it was faulty i would rma it.
i have just realised that the 55mn card dont clock as well as the 65nm cards
all i was doing was using the clocks from my old evga 65nm and applying them to the 55nm, and this doesnt work, hence me getting artifacts in atitool.
hey, im a reputable guy on here, and these no way i would put my status on the line.
i do see were your comming from tho, but really if it was faulty i would be in the car back down to stoke. i cant send it back on DSR because i drove to the shop and collected it and they can only if it was posted.
