Oculus app won’t let a game start unless it kind find the headset so that didn’t work. Already had HDR off, but checked it anyway. Xbox game stuff all off no change. Turned off hardware scheduling and did a restart but no change. Checked on my update history, last w11 update I installed was on 23/12, I didn’t start using the headset with pcvr until late on 24th and all was fine then. Also checked for any nvidia updates but none recently. I am running a Lenovo pro with rtx4080 card. Have read online that dual card laptops sometimes have issues and a fix has been to set the oculus and game apps so that the either only use the onboard card or the higher powered gaming card. Tried options described but zero luck.
one odd thing, I found last night that the preinstalled getting to know your touch controls demo built into the pc oculus app loads and runs fine so it seems to be a problem with the downloaded games I think. Weird as all worked before. I may just give up and just enjoy steamvr instead lol!
