25 Mar 2009 at 13:36 #1 Dozer 360 Dozer 360 Associate Joined 23 Mar 2009 Posts 11 Location Southampton what are peoples experiences with the ASRock OC Tuner? is it worth using or is it better to use the bios? (sorry if it sounds stupid im new to OCing)
25 Mar 2009 at 13:41 #2 Sash Sash Soldato Joined 26 Dec 2008 Posts 3,388 Location Edinburgh It will be good enough for basic mild overclocking. Anything more and you would be better with BIOS.
25 Mar 2009 at 14:21 #3 Dozer 360 Dozer 360 Associate OP Joined 23 Mar 2009 Posts 11 Location Southampton but it makes it unstable when i increase the multiplyer to 15
25 Mar 2009 at 17:00 #4 Sash Sash Soldato Joined 26 Dec 2008 Posts 3,388 Location Edinburgh Dozer 360 said: but it makes it unstable when i increase the multiplyer to 15 Click to expand... Need to specify your spec etc before we can give more help
25 Mar 2009 at 17:18 #5 rjk rjk OcUK Staff Joined 8 Aug 2007 Posts 25,532 use the bios for overclocking the only thing that cpu overclocking software will do for you is provide you with an unstable system
25 Mar 2009 at 17:18 #6 reflux reflux Soldato Joined 15 Nov 2007 Posts 13,192 Location Hertfordshire CPU overclocking software is not really worth bothering with to be honest. Do it in the BIOS, where you have the most control and stability
