Asrock X670E Stickers are useless
8 Oct 2013
This is so annoying
@Gibbo can you get some feedback to the supplier that they should spend like $0.05 on a foil or laminated sticker ?
Use a hair dryer on low setting, it will soften the glue to too help to remove the label.
Yeah I'm also getting some plastic toothpicks and some alcohol wipes.
I'm sure it will clean up anyway but hella annoying anyway.
Can see ocuk getting some RMAs for sticker glue I'm ram slots
That has to be one of the most stupid and unnecessary things I've seen.
If they insist on doing anything extra don't do something that just adds a headache.
This is why I avoid AsRock.
Not the best company.
Not true they make very good motherboards, some of the most reliable ones I have ever experienced over the many years, a sticker mistake has nothing to do with how good their boards are or being a poor company ( I personally have had great support from them if I needed it and they always came threw), just a poor sticker choice or the sticker manufacturer needs the blame.
Buildzoid often complains about them as a company.
They do make some good motherboards but HUB reviewed their Z690 boards and found that most of them were poor.
ASrock then told them not to review the boards or they would essentially be blacklisted. HUB refused and ASrock no longer sends them review samples.
HUB are not the first reviewer to be blacklisted by ASrock.
Why? I used 3 generations of it's mother boards and have no issues at all
Ah yes, why didn't you say? I can always rely on one persons experience to get a whole picture of a company's business practices and approach to products.
I'll rush out and buy one right now.
/s
There are many reasons why I don't like ASrock. The fact that they get all butthurt about poor reviews and try get the reviewer/youtuber to take down the poor reviews is a major one.
