Please no cloud suggestions; it is not a viable option with my poor home broadband upload performance.
My home router has two USB ports in to one of which I plug a memory stick that forms one component of a multiple layer backup strategy.
The reason for writing this backup layer to a USB stick is so that when I travel - which I do a lot - I put it in my jacket pocket and take it with me. If my laptop fails or is stolen I can still work if I use another machine. The backup utility always correctly updates the file images on the USB stick on arrival back home no matter how long I was away or how many changes were made.
What I would really like to do though is be able to trick the USB drive in to appearing to the laptop (Lenovo X1 with W7 Professional x64 SP1) as a network device with the same fixed I.P address as when it is connected to the router back home; I will then be able to maintain backups whilst travelling, further enhancing redundancy in the case of laptop failure of loss.
The workaround in use at the moment is to have two backups on the USB stick - one which is written when connected to the laptop and the other when connected to the router - and two corresponding backup profiles in the backup tool but is there a driver or hack that can help dispense with the workaround, please? It is *only* when the particular thumbnail drive is plugged in that I desire this behaviour.
TVM,
E6600
TVM,
E6600
