Be careful when buying one as if you don't keep your wits about you you could end up buying a Vauxhall.![]()
I've Owned the SRI-T (Pre-release for the GSI) for 2 and half years now. I've had 2 of these cars including the one I have now.
Common issues are Stem seals and turbo seals/turbos failing. Often due to not being looked after or using the wrong oil grades. You can get them to 300bhp quite easily as well they can be tuned to this on standard engine/block. Ideally anything above requires a Forge Build if you want it reliable and not running on borrowed time.
Fuel wise is all depending on how you drive it really. Average you'll be looking 250-300 miles to a tank driving round town.
Mines over 400BHP and it's pretty good on fuel if i'm on a run. Mines a weekend car though so fuel doesn't matter too much for me.
If you're looking at Tuning one if you buy one don't use Generic Tuners as another issue is rods being thrown through the block and pistons cracking the ring lands or melting due to generic files. Custom tune is the best for these engines. RND Motorsport is who does my tuning for me and is very well known in the Vauxhall Scene so just some extra info for you there bud.![]()
Are you interested in them for any reason other than the looks? Do you want any more from a car than aesthetics?
They're an old feelig thing now, not that quick and based on a car that, whilst OK was never much to shout about
300-310bhp you should be fine on a decent tune bud. A few have pushed to 330bhp but with ARP Rod bolts added. It's luck really as these cars are pretty old now.![]()
Forged Pistons & Steel Rods you'll be looking at £790 including Delivery. Then you need:
ACL Main & Big End Bearings: £100
LEH Oil Pump: £185
Top Bottom end gasket kit: £130
Balance Shaft Delete Kit: £160
Main end bolts: £25
Cambelt kit & Water Pump: £120
Titanium Retainers and Piper Single Valve Springs: £295
Block Machine work(Honing/Oversizing if needed)/Head Work:
Off the top of my head I think that's it for a decent solid engine build. Mines built to a similar spec & I usually build engines to this spec if i'm ever asked to build one. Fairly easy building a Z20 Engine. You'll just need to add the cost of someone building the engine for you to the above prices if you don't feel confident doing it yourself.
