***ASUS 4k2 MONITOR NOW AVAILABLE FOR PRE-ORDER!!***
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
It is what many have being waiting for, the new Super Resolution monitors and the first is here from Asus:-
Asus PQ321QE 4K Super-High Resolution Widescreen Monitor - Black @ £2,999.99 inc VAT
The ASUS PQ321Q True 4K UHD monitor provides stunning visuals with an ultra-high definition 3840 x 2160 resolution. The anti-glare 31.5-inch LED-backlit UHD display has a 16:9 aspect ratio and 140 pixels per inch (PPI) for highly-detailed visuals.
By doubling the number of horizontal and vertical pixels, the PQ321Q True 4K UHD monitor gives you every bit of detail, far surpassing that of a Full HD monitor. With four times the resolution of Full HD (FHD) and over 8 million pixels, experience larger screen real estate and clarity you have to see to believe.
The ASUS PQ321Q True 4K UHD monitor is a 10-bit RGB panels that delivers more natural transitions between different hues and offers a more flawless image than ever before.
The ASUS PQ321Q True 4K UHD monitor is built with an anti-glare Indium Gallium Zinc Oxide (IGZO) panel rather than traditional amorphous silicon. The IGZO panel supports much smaller transistors than amorphous silicon, which allows for much smaller pixels and much better detail. Couple with an ultra-wide 176-degree viewing angles on both vertical and horizontal planes, get a pristine image from virtually any angle. What’s more, the IGZO panel supports increased pixel transparency and reduced current leakage for increased energy savings.
The ASUS PQ321Q True 4K UHD monitor features DisplayPort and dual-HDMI ports inputs to connect to your various devices and PCs simultaneously. Built-in 2W stereo speakers simplify free space from needing separate speakers for a complete audio visual experience. Picture-by-picture (PBP) mode splits the screen down the middle to display content from two separate sources side-by-side to view images from different signals and easily switch between the main and PBP source, including audio. The thinnest 4K monitor available, the ASUS PQ321Q True 4K UHD monitor measure only 35mm at its thickest point, showcasing a modern design fit for anywhere in the home or office.
Features:-
- 31.5-inch 4K display with ultra-high definition (UHD) 3840 x 2160 resolution and 140 pixels per inch (PPI) for impeccable visuals
- An anti-glare, LED-backlit IGZO display delivers crisp, precise images with energy efficiency with an ultra-wide viewing angle
- DisplayPort and dual HDMI ports, Picture-by-Picture function, and built-in dual 2-watt stereo speakers
- The thinnest 4K monitor available, the PQ321Q is wall-mountable with full tilt, swivel, and height adjustment
Specification:-
- Panel Size: 31.5" 16:9 Widescreen
- Panel Type: IGZO / LED Backlight
- True Resolution: 3840 x 2160
- Pixel Pitch: 0.182mm (140ppi)
- Brightness: 350cd/m
- Contrast ratio: 800:1
- Display Colours: 1.07 Billion (10-bit)
- Viewing Angle: 176 / 176
- Response Time: 8ms (Gray-to-Gray)
- Trace Free Technology
- HDCP Support
- Colour Temperature selection
- Gamma Adjustment
- 2W x 2 Stereo Speakers
- Connections: DisplayPort, RS-232C, PC audio line-in, Earphone out
- Power consumption: 93W
- Kensington Lock
- Dimensions with stand: 750 x 489 x 256 mm (WxHxD)
- Dimensions without stand: 750 x 441 x 35 mm (WxHxD)
- Weight: 13kg
- Warranty: 3yr
Only £2,999.99 inc VAT.
ORDER NOW
Not even really 4k if its 3840 x 2160 :p
Hmm who would really buy a small 32in 4k monitor/tv? Seems overkill. I would have thought that 4k only really benefits the super large monitor/tvs where it needs it like 50in min?
Not really - your viewing distance for a monitor is likely to be a couple of feet whereas a TV will be 8-10 feet.
Having said that a 4K 50" TV is available stateside for under a grand ... I don't doubt this is a great panel but it is hell of expensive.
Asus is the first, so no competitors, this could merely be the price for being first to market.
But saying that remember monitors always cost more than TV's, for example 30" DELL at £1000. The flagship monitors have always cost big money, though I am sure once more 4k2 monitors arrive the pricing will go below £2000 for sure, but that could be 3, 6 or even 12 months. We'll have to wait and see. :)
Fact is Asus ones land end of next month hopefully. :D
Much want.. Hey ocuk when u doing another 5% discount code ;) This would make it more reasonable for anyone wanting one
Would have to wait for prices to die down and a true 4k screen to appear first.. this isnt quite 4k ;)
Those saying this isn't "real" 4K - it is as far as the television/monitor/active display industry is concerned. It's known as Ultra-high-definition. 4096 is used on projectors and in cinemas.
They should have called is 4X - as it's 4 times the resolution of 1080p.
given the huge cost, the gigantic outlay necessary for GPU requirements....... they could at least have made it a native PC ratio of 16:10 instead that cheapass tv ratio of 16:9
meh!
Monitors don't always cost more than TVs, in fact it's typical that monitors actually cost a noticeable amount less.
