Asus 970 Pro Gaming/Aura Mobo won't recognise my M.2
24 Jul 2017
Hi Guys,
Any help much appreciated. I built a budget system for my workplace, as I was able to pick up a bundle of mobo, 16gb ram, cpu and cooler all for £50 locally.
I bought the cheapest m.2 ssd I could find purely as a OS boot drive, after making sure it was compatible with my system using PC Part Picker.
SSD:
Western Digital Green 240 GB Internal SSD M.2 SATA
Mobo:
CPU:
AMD FX 6100
Problem:
Mobo does not recognise SSD in the bios, and neither does Windows when selecting a drive to install the OS on (it is the only drive plugged in)
Troubleshooting:
I performed a bios update to the latest release and used UEFI motherboard function to update, still not recognised.
Thought I would ask here, before I simply go and buy a standard SSD drive, as I'm not sure what my problem is since there are no compatibility issues using PC Part Picker.
I'm not a pro builder as I'm sure you can tell, hence why I'm here asking for help!
Thanks in advance.
You bought SATA drive when motherboard's M.2 slot supports only NVMe (PCIe) drives.
M.2 is only physical form factor/connector standard and many different buses+protocols can use it. (even USB)
