I have the above board and have 4 SATA drives on the NVraid sata ports - no problems
Tried to connect two more drives to the SIL 3114 ports and can get the PC to boot if raid disabled - but this disables the ports and no drives are there
If I connect the drives with ports enabled, it will only boot if I set the drives in a RAID configuration.
How can I simply add the two drives to the SIL 3114 ports as drives without RAID?
Running BIOS 1012 003 and latest 6.65 chipset and latest 1.4.3 SIL SATA drivers.
Thanks in advance![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
Thanks in advance
