Asus HD 4870 problem, again..
6 Jul 2009
So, I've been having problems with my Asus HD 4870. I had it RMA'd. but Overclockers said there were no errors found...
I have a screenshot of a FIFA 10 demo match, you can clearly see the problem. I can probaly get some others for you too, if you need.
And here's the GPU tool stability test.
As you can see, lots of fun pixel mismatches and errors.
Can anyone help?
i suggest you post in the customer service forum with that pic and see what they say
What are yor spec btw and have you updated your drivers?
forget the forum,
When you next send for another RMA use these images and request that they test it with multiple stability software including yours. Explain that you sent it away and got it back with no errors but the problem still occurs, another thing you could do is test it with a different graphics card from your mate or even your motherboard inbuilt graphics card to provide solid prooth it is the card in fault. Video would be ultimate proof if they refuse it still (shows the gpu your sending away been hooked up to your computer and running the software...)
forget the forum,
I had a similar problem with my 4870 toxic, and when i rma'd it to where i bought it, i sent them screens of the artefacts. They put it through the crysis benchmark which it failed due to memory corruption and they swapped it for a new one no probs.
