Hi,
I recently purchased the above graphics card from overclockers website and I'm having an issue where only one set of power LEDs are lit up green and the other red.
I'm upgrading from a Radeon HD 5770 with a CM silent pro 700W PSU. So I'm sure I have enough juice!
I'm currently using an 8-pin pci-e power cable from the psu straight into the gfx card slot which is displaying the green light. This same cable has a 6-pin coming off it which I then attached a 6 to 8-pin adapter (which was provided with the card) straight into the second slot which is
Showing up red and thus producing the no display signal. Do I need a separate second 8-pin pci-express cable coming from the psu directly or should the method I'm using work?
Sorry for lack of technical know how, any help would be very much appreciated. I can provide any other details which might help.
I'm using the i7 ocuk krypton overclocked bundle @ 4.0ghz (not sure if that would suck up the power).
Mobo = GA-X58A-UD3R
Thanks
Mobo = GA-X58A-UD3R
Thanks
