Asus maximums x hero problem?
10 Jan 2003
staines
Hi all
Set ram to xmp and the computer keeps cycling to mem test 3 - 4 times before it boots up.
If I set it to Auto ram runs at a lower speed but doesn't keep cycling mem test.
I'm using g skill trident z 4133 mhz ram
Anyone shed any light on what it may be or if I may need to change anything in the bios?
4133mhz on a four dimm board is the problem. Unless you have a very good imc on your cpu it's not running qvl or not....
Try 3866mhz first with xmp timings, then 4k and keep a serious eye on io, sa and cpu standby voltages set at auto for these speeds so as to keep heat and possible cpu damage in check.
Run around 1.15-1.25 tops with io=standby.
