- 24 Apr 2009
Hello All,
I replaced my old netgear router with the ASUS N55u recently, I changed for the aditional features and general speed boost all around.
This router has many PCs connected to it in a home environment, 4 of the PC are connected via Cat6 and a 8 port Netgear switch.
I'm having trouble unblocking ports on the router, I have followed a guide on portforward.com for the N56u which seems to have simular menu stucture, but then when checking the port is unblocked to my PC it is still shown as closed.
I have also tried disabling the Firewall and going through that route but the port still shows as being closed, I forget the website I used to check the open ports.
Basically I am trying to unblock/forward port 25565 which is commonly used for Minecraft, The PCs havn't changed since I switched over the routers only differences are that they have been assigned different Static IP addresses and the router is now on 192.168.1.1 rather then 192.168.0.1
At the moment, my brothers that own PCs on my Switch which is attached the router cannot play (run their own servers) Minecraft via lan or via a Dynamic DNS.
Sorry for block of text I'm sure there is much more information I could provide.
Can anyone suggest settings on the router that I might be missing or maybe other things that cause issues. I don't know if Minecraft would store Default gateways or something under its local files.
Thanks in advance for any help, have tried many things with not much luck, hopefully the experience and wisdom of this forum will help
