** ASUS Networking Products **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Today we have relaunched our range of Asus networking products.
The products we have listed are the height of the Asus product catalogue featuring only proven products. With a range looking to expand drastically in the next few weeks, OcUK is excited to start off with a brilliant set of products that will make your home & business networking lives easier.
With an expansion of the 'Black Diamond' branding due soon, OcUK are set to stock a wide range of the best networking products from a company looking fast set to take over home and business networking with stylish and capable products.
We will be working closely with Asus to provide aggressive pricing and attractive deals on these products on a regular basis.
Asus RT-N56U Black Diamond Dual-Band Wireless-N Gigabit Router @ £88.98 inc VAT
ASUS RT-N56U Black Diamond Combines High Speed Network Performance and Unique Design in Style
The revolutionary new ASUS RT-N56U is the most advanced wireless router available, challenging tradition by dramatically exceeding all expectations. This stylish network enabler combines a series of cutting-edge and powerful technologies to offer you an ideal internet and wireless package, complete with striking design.
Dual-band for Lag-free Entertainment
Double your wireless performance and bandwidth with simultaneous 2.4GHz and 5GHz bands speed up to 300Mbps concurrently. While basic internet applications like browsing or file downloading can occur in 2.4GHz, wireless HD content streaming takes place in the 5GHz band at the same time, so both achieve optimized speeds and you enjoy smooth, buffer-free HD content streaming.
Gigabit Internet Surfing with Hardware NAT
Equipped with a capable hardware NAT acceleration engine and built-in Gigabit Ethernet, it gives you full Gigabit internet performance, making its WAN to LAN throughput up to 2-5 times that of traditional software-based NAT Gigabit routers.
Powerful Online Multitasking at up to 300,000 Data Sessions
Support for a massive data pipeline of up to 300,000 data sessions means the RT-N56U has around 20 times the networking capacity of other high session routers, so multiple data transfer jobs don't slow down even during heavy load.
Plug-n-surf and Hassle-free Management
ASUS EZ UI offers you an intuitive router setup without read manuals. What's more, you can enjoy simultaneous printing and scanning by connecting an All-in-one printer to the router via the USB port. Also connect external hard disks to enjoy instant file sharing with family and friends!
Ai Radar Optimized and Reliable Wireless Coverage
This unique and efficient design drastically increases wireless signal coverage and quality without increasing power consumption. It intelligently adapts beam patterns to local conditions to enable higher-gain directional signal emulation. Ai Radar shapes signals to offer the strongest possible output, transforming what may be a weak omnidirectional signal to a stronger unidirectional one, improving throughput at same time.
Others blast signals everywhere, leading to signal loss. ASUS RT-N56U locks the wireless clients to provide dedicated and stable signals.
- Flexible dual-band lag-free entertainment
- Gigabit internet surfing with hardware NAT(While ISP support)
- Powerful Online Multitasking at up to 300,000 Data Sessions
- Twin USB ports enable multi-role usability
Only £88.98 inc VAT.
ORDER NOW
Asus USB-N10 Micro USB Network Adapter Wireless-N 150Mbps @ £19.99 inc VAT
The ASUS USB-N10 provides superior wireless performance for your PC compared to legacy wireless 802.11g technology. It uses a best-in-class MIFA antenna to deliver consistent HD quality data streaming and a much wider wireless operating range. In addition to providing better bandwidth and coverage, the 802.11n standard it's also backward compatible with 11g and 11b networks, ensuring existing networking hardware can be fully utilized. The wireless USB adapter incorporates an impressive MIFA antenna which is better than PCB and Chip antennas widely used in generic adapters.
Only £19.99 inc VAT.
ORDER NOW
Asus PCE-N10 Network Adapter - PCI Express @ £14.99 inc VAT
• WPS(Wi-Fi Protected Setup) - Quickly set up a secure wireless connection.
• Software AP - Connects your notebook and game consoles to the Internet.
• Supports WEP, WPA-PSK, and WPA2-PSK methods for enhanced security.
WPS (Wi-Fi Protected Setup)
For quickly setting up a secure wireless connection. Press the Hardware WPS button on PCE-N10 about 3 seconds, then press the WPS button on ASUS routers as well. Either you can choose to use software WPS, enabling the WPS utility in the WPS Wizard interface. And finish the setup with 3 steps.
Software AP
Software AP mode allows the WLAN card to act as a virtual access point. The computer needs to be connected to a wired network using an Ethernet connection in order to provide network access to WLAN client.
Only £14.99 inc VAT.
ORDER NOW
Asus PCE-N15 300Mbps 802.11B/G/N Wireless PCI-E Network Adapter @ £27.38 inc VAT
Asus PCE-N15; Wired; PCI; RF Wireless; 300 Mbit/s; IEEE 802.11b;IEEE 802.11g;IEEE 802.11n; OFDM
PCE-N15
300Mbps 802.11b/g/n Wireless PCI-E Adapter
- WPS(Wi-Fi Protected Setup) button - Quickly set up a secure wireless connection;
- Software AP - Connect your notebook and game consoles to the Internet;
- Supports WEP; WPA-PSK; and WPA2-PSK methods for enhanced security.
For quickly setting up a secure wireless connection. Press the Hardware WPS button on PCE-N15 about 3 seconds; then press the WPS button on router as well. Either you can choose to use software WPS; enabling the WPS utility in the WPS Wizard interface. And finish the setup with 3 steps
Software AP
Only £27.38 inc VAT.
ORDER NOW
Asus USB-N53 Wireless-N Network Adapter @ £33.98 inc VAT
The ASUS USB-N53 is a dual-band USB adapter that provides flexible dual-band connection for lag-free streaming and high performance networking. It also has a superior antenna design for extensive wireless coverage. With the bundled USB cable, you can flexibly adjust the antenna to receive the strongest signal. A friendly user interface utility allows you to install and use the application easily, making the USB-N53 a fantastic router both at home and on the road.
Features
• Flexible Dual-band connection for lag-free streaming and high performance networking.
• Power signal transmission for extensive wireless coverage.
• Contains a USB cable that allows you to adjust the adapter for enhanced reception.
Only £33.98 inc VAT.
ORDER NOW
Getting cable at my flat finally this weekend so will be having one of those routers.
Q - anyone know if PCI-E wifi NICs are better than USB, latency-wise? Of course they will be on paper but I want to know if there's any real-world difference.
That router looks rather tasty, especially as I suspect when VM double our speed I'm going to need a new router:) (not to mention the gigabit networking would be handy).
How good is the USB-N53?
Good enough for online gaming?
without a doubt. obviously, wireless is not incredible for gaming but it is certainly good enough for those who have no option to go wired.
If you have to use wireless, this is the best you are going to get :)
The N56U is a fantastic value router. The features it has are going to be well above and beyond the reaches of an ISP issued router.
If you are buying now, the N56U is the one to go for for a cable connection.
It might be worth waiting for this one though, I assume OcUK will be getting it in stock once it's released in the UK in the next few weeks.
RTN66U
as soon as the N66U is in stock at distribution, it will be live on our site.
the N56U is still going to be a current model and will be ran alongside the N66U
Hmm, was going to get the n56u. Think I'll read up on the 66u before buying. Getting a but fed up with rebooting the old netgear when we want to use the wifi on our phones.
Been running the N56U for a few months now, and have got nothing but praise for it. Range is very good and can even keep a signal through a thick wall, an exterior wall, forty foot of garden, and then into a brick built garage.
I previously had a WRT-610N which was excellent and the Asus is as good, if not better. The only issue I have with the Asus is it can only set internet access times for the router, rather than for individual MAC addresses (so if I want my teenager's Xbox to lose the internet at midnight, I have to lose it on my PC too). Other than that, the Asus is as good in every respect and the USB connection to my 1TB external drive - which acts as a cheap NAS - is actually better than the WRT as it is more reliable.
Our router runs my PC, my HTPC, two media centre extenders, my son's gaming PC, 2 Xbox's, 2 laptops, a Wii, a wireless printer, and 4 smartphones. Couple that with the kids spending 24/7 on-line gaming (when they're not at school), our routers never get an easy time and both Belkins I had used to fall over at least once a day. It took me almost 2 years to burn out my WRT-610N and the Asus is looking another one that is up to the job.
Honestly, can't recommend any other routers higher at the moment for a cable connection.
Tempting as my Stock Sky Router seems to be getting worse for latency and stable connection in STO and SWTOR lately :( and my parents don't seem to understand my need to put Ethernet all the way up to my room in the loft :( :P
Interesting..
I have a Linksys 610N running DD-WRT and it has been rock solid, my only criticism is the range of the signal, it drops off extremely quickly - would you say the Asus has better range???
Interesting..
Never did any tests unfortunately to say definitely one or the other. The thing on the 610N (v1) that finally gave up the ghost was the wireless, it became impossible to hold a connection long enough to do anything without dropping even though all the wired connections were still perfect. I do remember a few months before the end of the Linksys that my phone said it had WiFi in the garage but it couldn't actually open the OcUK forum page when I selected it, had to come half way up the garden for it to open. With the Asus I can open the forum in the garage (same phone) as if I'm standing in the next room to it. The problem I have is I cannot say whether this is due to an improvement in range over the Linksys , or if that was an early indication of ailing WiFi on a two year old, hard used Linksys at the time.
Sorry Edgedemon, apart from saying I've had no noticeable issues with the range on either, can't really say more than that from my experience. :(
