Asus P5N-E SLi nForce 650 (Socket 775) PCI-Express DDR2 Motherboard Audio Question
18 Oct 2002
Yorkshire
had a look through the thread already here but nothing on this subject.
Just wanting to know asap if this motherboard has optical out on the audio options ? as i'll need to get a separate sound card if not.
Thanks all,
paul_64l said:
it doesnt have the socket mate but im sure it has the pins
Dam :( looks like a sound card as well.
Just a final check, on some of the reviews i've just found it says.
Coaxial / Optical S/PDIF out ports on back I/O.
I though the S/PDIF is the port on the back so I can put my optical Toslink cable in ? or am I thinking of the wrong thing ?
update,
finally found a close up picture of the back of the board and yep like you said theres just the 3 audio ports and no optical out :( new sound card it is then.
another update.
having problems finding a soundcard for £40 that'll do optical out so thought i'd follow up on a comment you made in that.
"im sure it has the pins"
how exactly would I use the pins and what would I need and is it cheap :)
also on the mobo it says "S/PDIF component output" could I plug a mini optical into this ? as when I do a search for S/PDIF theres noly mention of toslink and mini optical.
any links/examples of suitable coaxial cable's that I can use bearing in mind that i've got to connect the other end to a optical in (toslink) type input on my surround sound amp.
