I've just recently tried installing my swiftech MCW30 Chipset waterblock onto my P5WD2 chipset. my computer then won't post, i then install the original heatsink and it boots fine, althought the bios has been reset. My diagnosis is that the waterblock isn't sitting on the chipset flat and is touching the metal "bits" on the chipset and shorting it. does anyone have any sugestions on how i can fix this? i'm thinking i need some sort of foam padding at each corner of the water block to keep it sitting flat. does anyone have any sugestions on what i could use?
Thanks a lot
Thanks a lot
