asus p6t deluxe v2-onbound sound any good
16 Apr 2009
im currently using an asus p6t deluxe v2 and wondered wether the onboard sound (ADI AD2000B) is any good?
would i notice an improvement if i bought an actual sound card?
thanks in advance
Ade
A difference in what? Movies, games or music?
Are you using analogue connections or digital out?
Will you be using headphones?
The ADI2000 are quite good, but still dreadful compared with a decent soundcard. Whether or not you would notice a difference depends on your speaker/headphone setup and how picky you are in regards to sound.
That said, you can find used X-FI Xtrememusic cards for 20ish.....probably best bang/buck card you can buy now.
games are my thing.
im connected via optical to a videologic 5.1 sound sytem ive had hanging around for a few years.
i will also be looking at buying a decent set of headphones for night time gaming.
if it's connected via optical then the soundcard doesn't do much other than transfer the digital bitstream to your 5.1 system. So it's perfectly fine.
