Asus P6T SE Screw Problem. Help Please! :)
27 Oct 2009
hey .. ive installed everything into my new computer a couple of weeks ago and have just added in my new gx card which arrived yesterday.
when i came to wiring the pc now ive noticed that a bunch of the screws have either came loose or came off completely that hold the motherboard inplace on the case.
ive just used the screws that came with mobo in the box so im abit puzzled to why they have came off when i thought i had scewed them all in correctly.
all the 9 screws that hold the mobo in place are all loose (or have came off) so i dont know what to do :S
does anyone have any idea on where im going wrong?
Did you get some screws with the case.. try those as it sounds like the screw holes/risers on the mobo might have a larger thread than standard.
The screws required to mount the motherboard on the brass stand offs will have been supplied with the case.
