Asus PG348Q replacement
21 Jan 2008
Cotswolds
Hi all,
My trusty Asus is still working, but I noticed some bleed all aroudn the edges this morning whilst booting up. I am not sure if that is a sign of near death, but I got this is September 2016 from OCUK, so it's done me well (as I'd hoped for a £1k screen!).
I don't think I want to/can go bigger because of where it is in my house.
I've been so long out of looking, not sure what to replace it with. I have an Asus 4080 gfx card.
Thanks,
James
How I wanted one of those first gen Gsync overclockable Ultrawides :D Had to settle for a 60 Hz no-sync one at the time.
34" 3440X1440 ultrawides are a lot more common now (and cheaper). You say you don't want to go bigger - what features would you want in a new (presumably 34" UW) screen?
You can get something similar that's an IPS panel again and with 120-144 Hz native for a few hundred quid now I believe. You'd almost certainly have to make do with 'Gsync Compatible' rather than having a full Gsync module like in your Asus.
At the other end of the scale there's OLED UWs, or bigger + higher res ultrawides, or ultra high refresh rate ultrawides (in VA or IPS I think).
Yeh I got a mini inheritance so blew 1/3 of it on that!
I don't think I can really go bigger, I have my office in the loft and it sits under a window/dormer (well slightly over).
Feature wise, I'd like to go 4k if I was going to spend the money and interesting on the gsync compatible - would save a few £££ for sure!
I take it you're thinking 16:9 4K, rather than 21:9 4K (aka 5K @ 5120x2160).
Sounds like space is a major issue. 4K 16:9s near the size of your current UW are restricted to either 32" or 43" IIRC - a massive gap - something to bear in mind.
I've recently gone for a 38" UW 3840x1600. Only 10 cm wider and 4 cm taller than my 34", but definitely feeling the upgrade :)
