asus rampage formula 3930k ram upgrade help!
9 Jan 2013
asus rampage formula 3930k oc@ 4.5ghz 1.33v stable
ram upgrade - is there point and will i see benefit, i am currently using 16gb 4x4 dimms corsair vengence @1.5v
i am trying to get rid of min fps drops anything under 60fps even 58fps plays like under 20fps meaning it gets really choppy :( is something wrong with my system, i have done fresh installs of os and lates mb drivers and gpu drivers
psu is thermaltake toughpower xt 875w if that helps.
For gaming GPU horse power is the main thing to consider. Maybe an upgrade there would be your best bet.
RAM will make a difference but not a massive one.
Have you overclocked the GPU??? That would be my first port of call. Then CPU further. 1600mhz RAM may be cramping the CPU for bandwidth, certainly 16gb is enough but maybe when the map is highly populated the RAM is not passing info fast enough.
Yup gpu overclocked 1200mhz core clock 6008mhz mem, when i overclock the cpu to 4.8ghz it has less drops bit still very noticable, what brand and speed memory is good for my set up, what would you recomend what would you use?
