Chaps,
I've recently acquired a X48 Asus Rampage Forumla, Q9450, and OCZ Reaper 1066Mhz, to join my 8800GTX in the LianLi case 1kw PSU.. I think i've got a setup problem, more than a broken MBoard. Basically, I built from scratch, OS etc. If I run the Mem at 800 all appears well - until I do something 3d... then nvkdlm.exe (nvidia driver) error. If I push the memory up to 1066, its dies on entering Vista every time Win32k.sys. Initially I thought nvidia Driver issue, tried one thing after another, nothing. Same old crashing in CoD4 (either hangs, Cod4 crashes, graphics corruption, or BSoD).
Well - i was so convinced by threads elsewhere that it was a compatibility issue with my old 8800GTX - bought a new 4870, stuff Nvidia. Guess what - games play for a few seconds and boom - off they go. Oh dear.......
I've tried change DRAM/CPU voltage up from others issues with this board, leaving everything at default, tweaking, etc. No joy. Only thing is the NB and SB massively hot - 52 / 54 after 30 minutes.... CPU is 23 constantly. The NB adn SB are hot to touch - memory seems steady at 37/38. I've used Thermalright U120 w/ Nocuna fan. Case is cool - I've added more fans previously and generally the box is cool.
Anyone used the ASUS Rampage Formula / Q9450 / OCZ 1066Mhz memory and willing to share their setup? I'm at the point i think possible the board might end up having to go back to OcUK if I cant get it going.
This has been a nightmare so far...
RAM - 5:6
surprised you aint already.
