- 1 Mar 2019
So after my third RMA of this monitor I thought my issue had finally been fixed, there was little to none of the horribly loud fan that plagues this display. Everything worked as it should for the first time since owning it. Welp, after 3 months the monitor has decided that it wants to (in roughly 10 second increments) gradually increase fan speed until it reaches (what I assume) is maximum RPM and then the monitor just shuts down, no power, no display, nothing.
Only way to get the screen back on is by switching off at the plug, waiting a few minutes, and then it can be switched on at the back. But after 5 minutes of use the same thing happens again, effectively rendering the monitor as a £2000 pound paperweight. Safe to say I regret ever buying this display, asus' customer support Is poor at the best of times and for a screen as expensive as this you expect a far better experience than I've had. It frankly is not as advertised. And I'm not going be satisfied with just a mere "refurbished" unit again on RMA at this point.
FYI: this has nothing to do with ocuk I bought the screen from scan, this is just a site with a better forum.
Any advice on how to proceed would be appreciated
