- 13 Oct 2010
Hi All,
I installed a new Asus Strix 1070 last week and it looks like the RGB lighting is faulty. When a static colour is chosen the backplate LED's are different from the rest of the LED's on the card although the backplate LED shows the correct colour as per the software colour chosen.
I found this out as I wanted to set the LED's to white but doing this makes the backplate LED white but the rest a purple colour, with one LED stuck on green.
I'm now not sure what to do as the card in general is great, no coil whine etc. The faulty LED's are not a deal breaker but it really niggles me that its not working as intended.
Do I get a replacement and chance the new card having coil whine or put up with it and keep the current card?
